| My Z's have the seams bent.. some I've done.. some were done before me.. just looks bad.. They make a Set of Vive Grips that have a Slide Hammer attached to the end.. it works great for grabbing the Seam and straightening it back down.. but you have to get the car up in the air to do it.. and if it's not jacked up roperly next time, you'll bend it again.. When I lift the 'Lowered Z' I have to drive it on Blocks before I can get the Lifting Arms of the Two Post Lift under the Car.. then I lift the Front on the 'Frame Rails' next to the Exhaust down Pipe.. and the Back Arms I lift on the Sub Frame Bolts.. with a 2*4 Block on top of the Arms.. Cj
